Enables the DiffServ code point to be overwritten in IP packets transmitted by the switch.
| port_list | Specifies a list of ingress ports or slots and ports on which to enable Diffserv replacement. |
| all | Specifies that DiffServ replacement should be enabled for all ports. |
| qosprofile | Enables DiffServ replacement on a
QoS profile. Note: DiffServ replacement will be enabled for
all QoS profiles if this option is not specified.
| qosprofile | Specifies the QoS profile number. |
N/A.
The Diffserv replacement feature functions for IPv4 and IPv6 traffic and is disabled by default.
The port in this command is the ingress port.
This command affects only that traffic in traffic groupings based on explicit packet class of service information and physical/logical configuration.
The following example enables DiffServ replacement on specified ports:
enable diffserv replacement ports 5:3,5:5,6:2
This command was first available in ExtremeXOS 11.0.
The qosprofile keyword and qosprofile variable were added in ExtremeXOS 16.1.
